Now that the cooler weather is upon us I've noticed that the heating and ventilation on my Xantia (1998 TD) does not seem very effective.
The blower appears to be working fine to the screen and upper body but there is only a little flow into the footwell's, the drivers being worse than the passengers.
The hot air that is produced is also not as hot as I'd like. The car runs upto temperature quickly but the guage only shows a constant 68 degrees (was a constant 82 in the summer with the air-con on) does this sound reasonable ?
Finally on a related matter, I have water ingress into the passenger footwell. Cit specialist has supposedly tested that the water is not getting past the screen side pillars (although I have my doubts now)and has cagged up the bottom of the screen seal on the passenger side as he said the water was dripping in through the heater vent. This has had no effect. I suspect the screen will have to come out and a new seal be fitted, any ideas ?
Cheers
Mark
xantia heater output
wrinklet1
Hi Mark,
Have you Tasted the water in the footwell? if you have does it have a sweet taste? If if has it may well say that your heater matrix has gained a leak. It it has your best way out is getting it replaced, not a great thought but one that would have to be done. Hole blocking mixtures are ok but long term it will go again. Hopefully it wont be antifreeze you taste.
If it doesnt have a sweet taste, have you had the windscreen replaced in the past? If you have, you will probably have to pump silicone or similar stuff up under where the glass of your windscreen meets the bodywork. The water goes upwards and into the cabin.
I have had both these problems on my car and solved both.
Good luck
Paul
Good luck
Paul
mark_sp
- x 1504
Mark,
68 is too low for the temp, which would suggest that the thermostat is shot - BUT - you say it comes up and stays at 68, which would indicate that the 'stat is working, but the gauge/sender has gone a bit awry. Worth of further investigation!
It's not unkown for the air direction mechanism on the Xantia to fail - check if the air flow changes as you move the lever.
You car will have air-con, so change the pollen filter if it's not been done - this can drastically reduce the air flow into the car.
As Paul says, water ingress is either the scuttle/screen leaking or the heater matrix.
lhm_leak
AndersDK
If you suspect the coolant thermostat - it's in fact quite simple to test in-situ :
Start the engine and let idle - hold a hand round the large top house running to the radiator. It should stay cold for several minutes - untill the thermostat finally opens by the hot coolant - THEN the temperature on the top hose should raise almost abruptly to the point where you have to remove your hand.
If the temperature on the top hose sloooowly increases constantly - and take ages (literally) to make you remove the hand - then the thermostat is shot (stuck open).
Turn off the cabin heat while testing - not to confuse you by the longish time before the thermostat then opens.
BonceChops
mark_sp
surfer
