C5 Spheres, suspension and struts
StevieOMG
Okay. I have a 2003 C5 110hdi estate. For the last four years or so it has sank at the rear overnight. Research on here tells me that it is a leaking strut. Lately I have had a metallic banging from the rear, occasionally when going over a poor road surface but always when I pop the key and the pump runs to level out. One large bang from passenger side rear. I got under It last night and there is a small leakage of LDS from the sphere gaiter. Is this small leakage combined with strut seal failure likely to cause the bang or am I also looking at trailling arm bearings. No creaking from rear and no uneven tyre wear. I know I have to fit a strut and gaitor but if the trailling arms are gone to, I have to question whether spending super funds on it is worth it. Any advice gratefully received.
waynedance
- x 8
Re: C5 Spheres, suspension and struts
I had a slight leak from my rear rubber boot, I ran a thin feeler gauge around the mating surfaces and added a strong cable tie to make it a tighter seal
I was told that there should be small amounts of fluid in the rubber boot hence the pipes that come of them. You may have a bigger problem if the car is sinking over night, is there enough fluid in the tank?
Found this below, not read it but worth a look if not already done so.
http://www.frenchcarforum.co.uk/forum/v ... ng#p398559" onclick="window.open(this.href);return false;
Volvo S80 D5.........
