It seems to be overheating had water steaming and pouring out of the cap on the headertank and dripping down into the wheel arch
C5 V6 thermostat location?
Quackers
- x 17
Can anybody tell me where the thermostat is for the cooling system for a 2001 C5 3.0 V6? or where the sensor is?
. It did in the winter do a little trick of going to max temperature for a short while when very cold (false reading), and i have seen other posts saying the sensor connector might be a little corroded so want to just check that first.
Ben82
- x 7
Re: C5 V6 thermostat location?
Number 9 for the sensor.
Number 4 for the tstat.
2004 Citroen C5 3L V6 Auto
Brit living in Sweden with an imported from Germany French Car!
Quackers
- x 17
Thanks for the diagrams, turned out to be the seal in the radiator cap in the end, cheap easy fix
