Citroen C5 Mark 1 - retrofit sat nav?
Hi chaps.
I've just bought a 2003 Mark 1 C5 V6 Exclusive SE for very little. It needs a bit of work, and just this evening I've been offered another C5 V6, this time just an Exclusive, although it does have full leather.
Would it be easy to transfer the nav from the SE into the other car? Or are we looking at some ridiculous task?
Cheers
Cheers
French is best.
- Locked user account
- My Cars: A used Citroen
- x 27
Re: Citroen C5 Mark 1 - retrofit sat nav?
I think the main concern is that you have to replace the entire top dash (due to the bigger screen), because they didn't make just the center (screen) part removable, it has to come off entirely, and be replaced with the top cover which has the larger opening (or taller screen compartment if you will) ... apart from that, if you have all the necessary wiring and equipment, it shouldn't be impossible ...
- (Donor 2018)
- Lexia Available: Yes
- My Cars: 2008 C6 2.7 Exclusive in Mativoire Beige with Vitali Leather.
2017 1.6HDi Berlingo Van - the works van - x 42
- Contact:
The other thing to bear in mind, of course, is that the Satnav may need to be coded to the car, I know is does it the later ones....
Steve
http://c6owners.org/index.php
- qprdude
- My Cars: Renault 5 TS, Renault 14ts, Citroen C5 Mk1, Renault Clio sport, Renault Laguna Privilege. Citroen C5 X7 Exclusive. Citroen DS5 D/sport . And around 25+ other brands from Morris Oxford to S Type jag and most things between.
- x 10
Plus, on that age car, you might be looking at map upgrades to 2007 (ish) with that Nav. I'm sure I read somewhere that they can only be upgraded for a few years.
Be interesting to know what the difference is between an Exclusive SE, and a "just an Exclusive" is.
Rick.
2013 Citroen DS 5 D/Sport
- waynedance
- x 8
- Ben82
- My Cars: C5 V6 2004
- x 7
Re:
My Exclusive has heated seats... no satnav or sunroof though.waynedance wrote:SE has sat nav, sunroof and heated seats as far as I know compared to mine.
sent via android power.
2004 Citroen C5 3L V6 Auto
Brit living in Sweden with an imported from Germany French Car!
- qprdude
- x 10
If it's anything like the later cars, it would depend on what the first owner required I think. There were so many things available as extras that it's difficult to know which model has what spec.
Rick.
- My Cars: C5 V6 Mk1 assainated by wife
Renault Kangoo 1.6 auto, tarted up and remapped
Still missing the Xantia V6
Not missing the AX - Contact:
You can still get up to date CD maps, I have 2012-13. Mine has heated seats only they don't get hot...
Lexia ponce
Lexia ponce
- x 9
My 2001 Estate SE has Sat Nav, (now losing one colour). Radio with CD multi chnager.
Leather all electric heated seats, except the drivers heater doesn't Large Panoramic Sunroof and thirsty 2.2 diesel on an HP20 auto box.
Frankly the SAT Nav is not worth having in my view, it's routing abilities suck and image detail is minimalistic by comparison with that available on the average smartphone.
About the only time I use it is when I am lost in a suburban area, if I tell it to go to HOME it will usually get me to a recognizable A road somewhere
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
- x 27
Well, you're talking about a device that is 13-14 years old (GPS), you really can't expect it to compete with anything newer than that, even if they're cellphones ... today's average smartphone's hardware can top almost every other device older than say 5 or slightly more years with no problems ... and the car user interfaces in general have come a long way during the years as well ...
- x 9
Can't argue with any of that mind I don't think it was that great when introduced.vborovic wrote:Well, you're talking about a device that is 13-14 years old (GPS), you really can't expect it to compete with anything newer than that, even if they're cellphones ... today's average smartphone's hardware can top almost every other device older than say 5 or slightly more years with no problems ... and the car user interfaces in general have come a long way during the years as well ...
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
- x 27
The thing that people often forget is that car manufacturers aren't manufacturers of car electronics, so you can't blame Citroen for poorly designed entertainment systems, rather, manufacturers of such devices ... the only blame which could be put on them is because they decided to put one kind of a unit, if they could put another (better) one, nothing else ...
Well both cars are now home and side by side.
The only two things my Exclusive lacks over the SE are sat nav and the under seat CD Changer. Tomorrow morning if the weather is good I'll start taking a look at the possibility of transferring both, or at least the changer!
French is best.
Luke, Check if you have the cabling under the seat for the CD changer.
If you do i have a spare changer in the garage as you will need to remove the seat fully to transfer the holding cage as well IIRC.
So what are they manufacturers of my friend?The thing that people often forget is that car manufacturers aren't manufacturers of car electronics,
Not Garrett turbo's, Teve handbrake systems, Bosch fuel injection. ZF gearboxes, Siemens Ecu's , Lesjofors springs, etc etc.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
