Headlights
captainslow72
Headlights
Hi all when I lock my Xantia 96vsx the head lights come on for about a minute then go off, after while they come back on any ideas as to why and how to sort it? Thanks
captainslow72
Re: Headlights
May have found the problem front drivers door plunger not working so have switched it with back one for now to see what happens.
agaafear
Re: Headlights
At least they don't flicker while driving - they do on the C5! A bit disconcerting but you get used of it!
begins
Re: Headlights
I got this flickering headlights problem on my C5. Do you know the exact cause and the solution to this problem? I was of the thought to change the headlight bulbs, which are very expensive to me.agaafear wrote:At least they don't flicker while driving - they do on the C5! A bit disconcerting but you get used of it!
Thank you.
Regards,
Northern_Mike
