i have an R reg XANT TD in today and i noticed the injector with the sensor attached to it, is on the third cylinder from the cam belt end,
when it is usually on the second one,
can this cause any issues
what difference if any dose it make
- x 94
Regards, malcolm.
Xaccers
- x 188
Re: what difference if any dose it make
I'm surprised you don't have the ECU light on.
That sensor and the TDC sensor are used to adjust the pump timing slightly.
DIY sphere tool
DIY sphere tool
Are you sure that's not the correct place for it, Citroen engines are normally numbered one to four from the crankshaft end.
- x 94
all the ones i have seen it been on the second injector from the cam belt end,Gibbo2286 wrote:Are you sure that's not the correct place for it, Citroen engines are normally numbered one to four from the crankshaft end.
which PSA call No. 3
Regards, malcolm.
Old-Guy
- x 32
For "crankshaft" read "flywheel".Gibbo2286 wrote:Are you sure that's not the correct place for it, Citroen engines are normally numbered one to four from the crankshaft end.
OnlineRichardW
- x 1496
Don't think it will matter - 2 and 3 rise together, so fire at the same crankshaft position - OK so it's half a camshaft turn out, but think it only monitors crank position. I think if you put it on 1 or 4 then it would confuse the ECU!!
Thanks old-guy, I'd just arrived from a 150 mile drive when I posted thatOld-Guy wrote:For "crankshaft" read "flywheel".Gibbo2286 wrote:Are you sure that's not the correct place for it, Citroen engines are normally numbered one to four from the crankshaft end.
