C5 Series II Pipes
UVG
C5 Series II Pipes
Unread post by UVG »
Hi All
well its that time of year again....and the C5s just failed its MOT :( one hydraulic pipe from the rear suspension and the two rear brake pipes.
no worries say I just call Pleiades .... but they say the hydraulic pipes on a C5 use a different end to what I'm used to (CX, BX, Xantia, XM) and they don't do them :grr:
so now what? I don't want to go to Citroen unless I have to cos we all know they will charge an arm and a leg
so does any one know if the brake pipes will be something I can get made as the C5 uses a "normal" braking system
and does any one know anything about the hydraulic pipe ends or where I can get some made
any info greatly received
Cheers
UVG
x 1240
Re: C5 Series II Pipes
Unread post by Peter.N. »
If they are not severely corroded give them a clean and grease them.
UVG
its already fail Peter if it doesn't go back with new metal he's not going to pass it
plus to be honest I only bought it last year and plan on keeping it for a while so it will have to be replace sooner or later
x 1488
See this thread: http://www.frenchcarforum.co.uk/forum/v ... =3&t=48367" onclick="window.open(this.href);return false; where there is a pic of the pipe end in question, and a link to someone that can make them. Don't know about the brake pipes, they might just be 'standard' flares?
x 5674
I'm sure that this has been mentioned previously and that C5 are just standard pipes/flares.
qprdude
x 14
Unread post by qprdude »
UVG, you dont say where you are in the UK but to be honest, a lot of hot air is expended about making brake pipes. When I worked in the ship building industry, we used to get people come into the workshop with old brake pipes and we checked the flare, and if we had the right flare tool, we made them up there and then. Lots of engineering firms have pipe benders and flaring tool around the place.
We always tried to us Kunifer pipe ,and of course the customer supplied the fittings and unions. Depending on condition, quite often the old fittings could be cleaned up and re-used. Some were so badly pitted that they had to be replaced, but not often, and we always gave the new bits a coat of copper-slip.
Don't know where you are, but it might be worth phoning some local engineering/fabrication shops.
Rick.
2013 Citroen DS 5 D/Sport
UVG
thanks for the link Richard I contacted the company and ordered all I need plus one I don't and it still came to less that £50 inc p+p guy I spoke to was very helpful i'll come back and give details once I receive them
UVG
I did promise to come back with feed back and I have just never got round to it. (hangs his head in shame)
the link Richard gave above shows pics and the company was very helpful. the ends are something unusual and the pipes supplied were actually genuine citroen parts
I found changing them to be very easy compared to the hydraulic pipe I have changed on previous Citroens. The spanner size on this style of pipe is bigger than the usual citroen joint so less chance of rounding of the flats.
the brake pipes were just "ordinary" ends that you might find on any car and were nothing special.
the whole job two brake pipes and two hydraulic pipes (I know they are all hydraulic pipes but you know what I mean) changed and system bled took less than 2 hours
UVG
