guys
when i put my head lamps on i don't have any light in the dashboard,
I'm assuming its a bulb .. what sort of fix is this are they any instructions anywhere
cheers
citroen synergie 2.0 hdi 2001 no light in dashboard
shahidocean
- x 6
- x 1240
Re: citroen synergie 2.0 hdi 2001 no light in dashboard
My 406 is the same, I think they still use bulbs and removing the instrument panel is not usually difficult, a Haynes manual or someone who has done it will tell you.
shahidocean
- x 6
excellent i'll have a look
thanks
shahidocean
- x 6
actually the whole dashboard looks dead no mileometer speedometer nothing ... i've seen those on ebay what else needs replacing to make it good
- x 3296
I would start checking fuses. On the Xantia there is a fuse for the instrument panel. If yours has such a fuse, it would be reasonable to assume that if the fuse has failed the instrument panel would stop working.
