2010 auto c5 getting stuck in park
mooseshaver
As above. Been getting worse for a while. I assume if it's not the brake light switch, then it's something in the centre console and expensive?
Gone cars.
C3 1.4 HDi 92 SX 52.
Saxo 1.1 East Coast.
Gone cars.
Jodyone
Re: 2010 auto c5 getting stuck in park
There is a brake pedal switch in the C6 and C4 that can cause this if it fails (among other things). Is that what you mean by brake light switch?mooseshaver wrote:As above. Been getting worse for a while. I assume if it's not the brake light switch, then it's something in the centre console and expensive?
If not, the one I'm thinking of is in the passenger footwell, and is a plastic plunger assembly with an electrical switch, which registers when you have your foot on the brake. It may well be the same part in your car (so much else is common). I replaced the one in my C6 when I had the same problem. Only about £20 from a dealer, and a 10 minute fix.
EDIT- It's item 6 here:
2006 C6 Exclusive, 2.7 HDi
mooseshaver
Oh thank you!
I think that's what had been ordered. It's had to come from the internet as the local dealer had been awful with this part.
It's a friendly garage that will be fitting it.
I'm hopeful it's just this.
Thanks again
Thanks again
Gone cars.
Gone cars.
mooseshaver
new switch and no change
Gone cars.
Gone cars.
chrisjvm
I had the same problem with a Volvo ...
It turned out to be the button on the gear selector getting stuck slightly so that it wouldn't move unless I pulled the button out fully by hand ... Might be worth checking.... Nothing ventured,nothing gained ...
'09 Citroen C5 3.0 hdi Tourer.
'15 Peugeot 308 1.6 bluehdi SW.
'89 VW T25 Westfalia California.
'01 BMW 530i auto.
'01 BMW 530i auto.
mooseshaver
I've booked it in somewhere as I have a warranty with warranty direct.
Who wants to guess where warranty direct have told me to take it?
Gone cars.
Gone cars.
mooseshaver
The C5 doesn't have a little button it just uses the foot on brake method. I guess it's a relay in the panel somewhere but I couldn't work out how to take it apart and I would be just guessing.chrisjvm wrote:I had the same problem with a Volvo ...
I'm not mechanically minded so simple stuff is beyond me.
Gone cars.
Gone cars.
Lighty
- x 35
It is a relay, have changed one before, unfortunately due to Alzheimer's , I can't remember where it is .
I you press the brake on & off, you should be able to hear it (when it works )
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
Citroen C15
Citroen Ami
mooseshaver
Thanks, I've noticed the click when it works. It seems to work better when it's been in the sun.Lighty wrote:It is a relay, have changed one before, unfortunately due to Alzheimer's , I can't remember where it is .
Gone cars.
Gone cars.
mooseshaver
It's the relay. Waiting for new part and Warranty Direct to approve
Gone cars.
Gone cars.
mooseshaver
All fixed! Feels like a very smooth action now the relay not blocking it. Must have made it notchy when it wasn't actually stopping it. Happy
Gone cars.
Gone cars.
