Anti pinch on citroen c5 2010 o/s front window.
adiebrown
Unread post by adiebrown »
Hello,i have just replaced the cables on citroen c5 2010 o/s front window regulator but window is not operating in the correct manner.Sometimes when you operate the switch to upwards the window goes down, can anyone tell how to reset the anti pinch on the window motor,Many Thanks Adie Brown.
vborovic
Locked user account
x 40
Re: Anti pinch on citroen c5 2010 o/s front window.
Unread post by vborovic »
I think the window movement is wrong, you have to reset it (will try and find the right topic where this was explained) it goes something like this: try to push the window to the top with the button (not automatic), and then you press the button and hold it to go down, and you still hold it pressed down for several seconds after the window reached it's max down location ...
