Hi. I have a 2.0 Grand Picasso diesel on 07 plate. I am in the process of changing the rear suspension airbags and have discovered that the little collar that you pull to release the pipe from the bag is broken on the passenger side. The upshot is that I cannot get the airbag off in the way it should be done and I suspect I will have to cut it off around the inflator pipe. I assume that I will have to buy an entire new pipe just because of this minor problem. If so, where is best to get them please and any hints on getting the pipe out without Stanley knifing it to death. Alos, is it a pig to fit a new pipe into the compressor?
Thanks in advance.
C4 Grand Picasso pneumatic airbag pipes where to buy?
Keith J
- x 1489
Re: C4 Grand Picasso pneumatic airbag pipes where to buy?
Suspect it will be dealer only - looks like the pipes are around £25 each.
You're brave - noraml thought with these once they start to give trouble is to bin the pneumatics and fit springs instead....!
Keith J
All sorted thanks. New pipe not required thank God. Thanks for the reply RichardW.
