Xantia plumbing
KennyW
x 165
Xantia plumbing
Unread post by KennyW »
Hi All,
Can anyone tell me if pipe no 9 from front and rear braking supply (1st diagram) goes over or around diesel tank on my old gal as I will have to probably have to replace same when I trying to fix my problem with my feed pip into anti sink sphere.
see other thread below
http://www.frenchcarforum.co.uk/forum/v ... =3&t=48200" onclick="window.open(this.href);return false;
Kenny
C3 1.4 petrol (SWMBO)
VertVega
x 13
Re: Xantia plumbing
Unread post by VertVega »
IIRC rear hydraulic pipes and rear abs wires are together and goes under the fuel tank but rather close to the left side so that the tank can be removed/dropped without breaking the pipes :) The pipe/wire channel (plastic, rectangular profile) ends somewhere right after the fuel tank next to the rear left wheel and pipes are visible there. The horizontal line (front-->rear) makes a 90 degrees turn and goes up vertically to top of the rear cross member (correct term?) and another 90 deg turn over the cross member.
x 3298
Re: Xantia plumbing
That looks like the pipe that Northern_Mike had problems with on his V6. As VertVega says, It does run up and around the cross member, but not over the fuel tank.
Re: Xantia plumbing
Kenny
I replaced my pipe number 9 with the full story here-bit of a slow start but stick with it!
All you ever wanted to know about pipe no 9 but were afraid to ask
It includes this diagram of the rear end plumbing of my 1.9tdsx (1994). Brake pipe no 9 runs across the top of the rear subframe to a K connector at the offside. I joined mine at a straight bit at the nearside rear.
kind regards Neil
KennyW
x 165
Re: Xantia plumbing
Thanks for the replies Guys,
Neil,
I remember reading your post with interest but couldn't recall the routing for pipe No 9.
Suggestion for our admin team: How easy would it be to put together some the threads re Xantia plumbing in a sticky
Kenny
x 5676
Re: Xantia plumbing
I'll sticky this and feel free to expand on it.
KennyW
x 165
Re: Xantia plumbing
Another useful link re HP pump seal rebuild
http://www.frenchcarforum.co.uk/forum/v ... =3&t=48274" onclick="window.open(this.href);return false;
KennyW
x 165
Re: Xantia plumbing
More plumbing Non Hydractive supply pipe routing
http://www.frenchcarforum.co.uk/forum/v ... 44#p403844" onclick="window.open(this.href);return false;
KennyW
x 165
Re: Xantia plumbing
Another link Rear LHM leak
http://www.frenchcarforum.co.uk/forum/v ... 75#p397975" onclick="window.open(this.href);return false;
KennyW
x 165
Re: Xantia plumbing
Another plumbing link Front to rear pipe no
http://www.frenchcarforum.co.uk/forum/v ... =3&t=42435" onclick="window.open(this.href);return false;
KennyW
x 165
Re: Xantia plumbing
Another link re plumbing Xantia hydraulc Pipe
http://www.frenchcarforum.co.uk/forum/v ... pe#p335794" onclick="window.open(this.href);return false;
KennyW
x 165
Re: Xantia plumbing
Another link RE brake pipes at rear and feed line from front
http://www.frenchcarforum.co.uk/forum/v ... 02#p320802" onclick="window.open(this.href);return false;
KennyW
x 165
Re: Xantia plumbing
Hi All,
If anybody has any threads re the 'plumbing' please add them here hopefully it will be a quick reference for everyone.
KennyW
x 165
Re: Xantia plumbing
Another link rear LHM leak
http://www.frenchcarforum.co.uk/forum/v ... =3&t=43884" onclick="window.open(this.href);return false;
KennyW
x 165
Re: Xantia plumbing
Another link Late MK 2 /C5 suspension
http://www.frenchcarforum.co.uk/forum/v ... =3&t=48367" onclick="window.open(this.href);return false;
