brake bleeding
iroc
brake bleeding
Unread post by iroc »
hi guys this car is driving me nuts getting it ready for it's mot so when checking the car out i noticed the brake pedal was creeping down when pushing on it so sent for a repair kit now the brakes wont bleed up after about three ltr fluid i now have a brake pedal ! then when i start the engine the pedal goes to the floor and no brakes any ideas guys
cheers arch
2001 Picasso 2.0 HDi 90bhp
x 1240
Re: brake bleeding
Unread post by Peter.N. »
Sounds as though you still have some air in it, sometimes the fluid can bypass air on certain sections of pipe and leave it in there. I think you can get a 'reverse bleed' kit the pumps the fluid in from the brake end.
BX
x 19
Re: brake bleeding
Unread post by BX »
On many cars from about year 2000 you need a diagnostic tool to bleed the brakes if air gets into the abs pump. The pedal creeping down is a common symptom of this as is the situation you describe.
iroc
Re: brake bleeding
hi guys just a wee up date and to say thanks for the help the brakes are great but still some air will breed again next week
cheers arch
davie206
Unread post by davie206 »
Is gravity bleeding any good on peugeot?
Sent from my C6603 using Tapatalk
