Well my car hasn't been particularly kind to me over the last few months - new clutch, cat converter fell off, few bits on the MOT and now some lectrickery troubles.
I noticed when driving back to Kent last weekend that having the headlights, seat heaters, stereo, wipers and rear screen demister on at the same time was causing the battery discharge light to illuminate dimly. On inspection the naff bit of wire connecting my battery positive to the rest of the car has gotten worse and appears to be limiting current draw (although no trouble starting). So replacement loom purchaced from the stealership for picking up today (£120
I've also just noticed that with the engine running the voltage goes up to 20v as opposed to the usual 14v...
The alternator is a year old - admittedly it's an aftermarket job.
Is this likely to be a failed voltage regulator in the alternator or the alternator acting as a current source and supplying higher voltage to maintain its output current at higher load?
Either way I need to sort this before the battery or something more expensive goes pop...
Cheers,
Alex
