Xantia 1.9TD starter motor clicks rapidly
Xaccers
x 185
Unread post by Xaccers »
Up on holiday near Whitby and just went to start Cassy but her starter motor just clicks rapidly like its slipping.
Called GEM so will see how they go.
Fun fun fun
DIY sphere tool
x 1238
Re: Xantia 1.9TD starter motor clicks rapidly
Unread post by Peter.N. »
I would say either you battery has had it or you have a bad connection somewhere.
Xaccers
x 185
Correct.
GEM's local mechanic came out and got Cassy started with his power pack.
The battery isn't holding a charge so I've got a new one on order to arrive tomorrow
DIY sphere tool
x 1238
That's the most likely problem, modern batteries often fail suddenly.
x 8093
Gosh, another battery Xac? :o
I have a spare 1.9TD starter motor here with your name on it should you want it. Untested though but was good when removed from vehicle about 60 years ago......
x 1238
Inertia engagement? :-D
Xaccers
x 185
CitroJim wrote:Gosh, another battery Xac? :o
Its not Cassy's original one is it?
I think this battery is an older on and had spent some time flat. Pretty sure Juliet and Jenny got the new batteries recently.
Still, ECP have got a sale on so getting a Bosch one delivered today.
DIY sphere tool
x 8093
Xac wrote: Its not Cassy's original one is it?
Nope, this one came from somewhere else...
Xaccers
x 185
Fitted the new battery and found one of the main + cables had popped out so it could be a combination of situations.
DIY sphere tool
