My 16 year old Synergie (XUD, SX with climate control) has a fluid leak.
All the control side works - you can hear the compressor pump kick in and so on, and the system delivers air where it is told to - just not cold air. For a few years it has had some fluid loss, but it passes the vacuum test and an annual top up has kept it working. Last summer the top up lasted only a couple of weeks so it looks like I need to get a professional job done to check it all out.
I guess the most likely source of leakage would be the condenser radiator, but does anyone have experience of other likely issues and how hard they might be to fix?
Synergie leaky aircon question
Richard_C
- (Donor 2026)
- x 224
Richard_C
- x 94
Re: Synergie leaky aircon question
i suspect the condensor has rotted away/through from build up of leaves and rubish between it and the main rad,
this is what i found when we did an enginge change on my daughters 02 Picasooooo,
we sourced a new condenser for £100 quid fitted then got my friend who is a mobile air con repairer to check and re/gas the system,
were are you located as my friend price's are very reasonable
Regards, malcolm.
