brake pad sensor
froggy
(Donor 2026)
x 4
brake pad sensor
Unread post by froggy »
Hi my S1 Xantia. I have just reconnected the wires to the front wheel brake sensors. someone in the distant past had decided to cut both wires ! Iam finding , sometimes that the brake pad sensor light light flickers on and off from time to time but never under braking ! any advice greatfully received, cheers Terry.
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
x 94
Re: brake pad sensor
Unread post by citronut »
sounds like theres a bare wire touching to ground somewhere in the circuit
Regards, malcolm.
froggy
(Donor 2026)
x 4
cheers
Terry
dnsey
x 19
Unread post by dnsey »
You need to dress the sensor wires carefully, or they are inclined to rub on the rims, wearing away the insulation.
Old-Guy
x 24
Unread post by Old-Guy »
I've recently repaired one on the green lady - the cable has TWO cores, one of which is grounded on the strut. So if the repair cross-connects the two wires.....
