Anti roll bar bushes ARB
Welshy_Pete
Unread post by Welshy_Pete »
I was wandering what symptoms do you get with anti roll bar bushes ARB.
I have changed the P bushes and drop links things are much better now. But the anti roll bar had to be moved over a bit to stop it catching. It's a bit better but still needs moving over a bit more. So will the anti roll bar bushes make any difference?
Is there anything that stops the anti roll bar moving to one side to much? I will a just again more but just want to know if things can still move?
I have 19mm ones for the 306 hdi.
Oldpug
x 94
Re: Anti roll bar bushes ARB
Unread post by Oldpug »
I had a ARB moving on a 306 and touching a lower arm. I put a HD jubilee clip on the bar next to the mounting.The ARB bushes are only a few quid so replace them as well.
