Key programming DiagBox
- x 1480
Anybody know where it is hiding? Trying to program a new key to the C4 Picasso. Go into BSI after global scan, but there is no obvious option. Configuration only gives an option for 'manual configuration' which I'm a bit scared to press in case it starts to unwind the BSI Config...
but maybe that is where it is? Nothing else looks likely??
Mandrake
- x 694
Re: Key programming DiagBox
Are you in the diagnostics section ? Key programming is usually under the replacement parts menu tree not diagnostics. Failing that I can have a look this weekend
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
zharn
Im after someone who can do VIN to PIN so i can make up a spare key. Any suggestions?
- x 1056
Should be in BSI then learning menu.
- x 1480
Found it - have to go through the 'Pack reparation' button under BSI - what ever that means!! Anyway, new key coded, so we now have 2 working remotes again. Let's hope SWMBO doesn't throw another one away....
- x 1480
Body systems interface (I think...!) - what are you trying to program? BSI only used on later multiplexed cars - Xantia for instance doesn't have one.
Dave1987
achieved via lexia diagbox
view the last post here
http://www.frenchcarforum.co.uk/forum/v ... 32#p437332" onclick="window.open(this.href);return false;
