C5 tow bar electrics.
carnage65
Unread post by carnage65 »
I have worked out the wiring diagram for the back lights but I am having trouble getting a feed for the reverse lights. The only feed i can verify is on the tail-gate, but i'm hoping i don't have to run a wire all the way from the tail light cluster to the lights on the tail gate.
Any suggestions would be welcome. :lol:
George
Trainman
(Donor 2018)
x 43
Re: C5 tow bar electrics.
Unread post by Trainman »
Might be handy if we knew what year the car is?
Steve
http://c6owners.org/index.php
x 94
Unread post by citronut »
i dont know if this is for the same year as you C5 but this is the type of thing you require, they are plug and play dedicated looms
http://tinyurl.com/nhr89rd" onclick="window.open(this.href);return false;
or look through these
http://tinyurl.com/ofvxetb" onclick="window.open(this.href);return false;
Regards, malcolm.
carnage65
The car is 2005 55 registered
carnage65
W
x 94
carnage65 wrote:W
???????????????????????????? :-D :wink:
Regards, malcolm.
x 1056
Unread post by wheeler »
There's a 16 pin connector just below the C pillar trim that has a reverse light feed in it, used it a few times for parking sensors. It's been a while but from memory it's the drivers side the connector is behind, if no joy check passengers side.
