I have an intermittent immobiliser problem on my 306. About once a week when i put the key in the ignition and turn, the immobiliser seems to just cut all the power to the car.
The only way i have found of getting the car started is to disconnect the battery for 30secs and try again, normally after 4/5 attempts it starts.
I have had the ECU tested by pug and its fine...(the problem did not happen for the whole week it was in the garage!)
Has anyone had this before?
Is it possible to disable the immobiliser?
The car: 306 Xsi 2.0 W-reg
Cheers in advance
Eugene
306 Immobiliser intermittent
JR
It is possible to disarm the immobiliser by entering the correct code, waiting for the three bleeps and green light. Afer this you can simply disconnect the immobiliser and it will never bother you again. It is important not to disconnect it before you have entered the correct code as this can mess up the ECU.
I recently had a similar problem to yourself, where the car would cut out and not accept the immobiliser code. After a few days of hunting around, I noticed a lose cable right at the base of the ECU, which solved the problem.
- x 1056
Paulmi16
- x 3
E.Everson
