Part number for front spheres
osx
- x 15
What is the part number for the front spheres (C5 X7), or is there a part database I can search?
C5 X7 Exclusive 2.0 HDi Auto
rory_perrett
Re: Part number for front spheres
Front Sphere part number 5276 34 showing as £79.61 + VAT (£95.53) on http://service.citroen.com" onclick="window.open(this.href);return false;
Seem to be the same for all variants but would need your exact model spec (body style and engine designation) just to be sure
osx
- x 15
Thanks. Have found both 5276 34 but also 5276 27
rory_perrett
5276 27 is attached to the suspension rigidity requlator (whatever that is) of which there seems to be one on the vehicle.
5276 34 is the sphere on the top of the front suspension strut so two per car.
osx
- x 15
I guess the first one is for the sport suspension setting. Do you know if they are able to check the spheres?
rory_perrett
The spheres can be tested to see if they are still at the required pressure. You need someone with a sphere tester and the spheres will need to be removed from the car.
