Mileage query.
Northern_Mike
Mileage query.
The speedo on my V6 is consistently 10% out.
Does this mean then, that instead of the indicated 138,800 miles it's actually only done 124,200 miles?
Sent from my GT-I9505 using Tapatalk
Xaccers
x 186
Re: Mileage query.
Unread post by Xaccers »
Depends.
You'd have to check it by driving at a constant speed for an hour and check if you've done that many miles or less on the odometer.
DIY sphere tool
rory_perrett
Re: Mileage query.
Unread post by rory_perrett »
My speedo is about 7% out and the mileage is out by the same so I guess my 306,000 miles is really only 285,000!
Eddie Nuff
New User
x 38
Unread post by Eddie Nuff »
The law states that any vehicle under 3.5t must have a 10% tolerance on the speedo. The tolerance is one way only showing that you are traveling faster than you actually are. Therefore at 50mph it's quite possible that you could be doing 45mph.
Any vehicle over 3.5t and fitted with a tachograph is only allowed a tolerance of 4%. Therefore at 50mph this type of vehicle could be doing 48mph.
Northern_Mike
Re:
Eddie Nuff wrote:The law states that any vehicle under 3.5t must have a 10% tolerance on the speedo.
No, it doesn't. It states a speedo is *allowed* to over-read by 10% but not under-read. There is no requirement for it to over-read. If that were true, my Berlingo, which is 1mph out throughout, would be illegal..
"The Motor Vehicles (Approval) Regulations 2001[12]... etc .. etc... As with the UNECE regulation and the EC Directives, the speedometer must never show an indicated speed less than the actual speed. However it differs slightly from them in specifying that for all actual speeds between 25 mph and 70 mph (or the vehicles' maximum speed if it is lower than this), the indicated speed must not exceed 110% of the actual speed, plus 6.25 mph"
Eddie Nuff
New User
x 38
Re:
Before you get your Cherry Picker out it would be wise to read the whole post:-
Eddie Nuff wrote:The law states that any vehicle under 3.5t must have a 10% tolerance on the speedo. The tolerance is one way only showing that you are traveling faster than you actually are. Therefore at 50mph it's quite possible that you could be doing 45mph.
Northern_Mike
Re: Mileage query.
You would be wise to quote the regulation direct from the government legislation website, as I did. Not make it up as you go along.
Oh, and learn the meaning of the word "must'..
Xaccers
x 186
Re: Mileage query.
You would all be wise to wind your necks in and learn to be grateful that information has been offered up for polite discussion. This is not the place for nit picking or badly veiled put downs
DIY sphere tool
Sl4yer
Re: Mileage query.
Unread post by Sl4yer »
Not a Citroen, but anyway...
I used to have a company Leon (near to the end of the original model, 150hp diesel FR, and a fantastic car!). I always thought the speedo overread, and that was proved by satnav. Interestingly though, if the cruise control was set to hold a certain speed (say 60mph, set from the speedo) the trip computer would record an average speed lower than that set. A speed which would correspond with the satnav readings. The mileage reflected the true reading, not the speedo reading. So, basically, the computers knew what the car was doing, but the speedo displayed something different. The difference was large - indicated 90mph was actually 82.
I'd bet most 'modern' cars (where the speed signal is digital, rather than via a cable) are similar, and the mileage will be correct.
Now Citroenless for the first time in 20 years
2008 Mazda RX-8 231
2007 Honda CR-V Auto
