Now I have the stretchy gaiter but how to remove the power steering ram from that stud. If anyone know please share
Xantia steering rack gaiter
xf1ref
- x 12
Hello to all, I want to change the gaiter from the power steering ram side and I found over the internet that is a way with a stretchy gaiter.
Jaf
- x 42
Re: Xantia steering rack gaiter
Take the nut off and then move the steering from side to side a little, then gently lever the ram off the stud. Did this job a few months ago and it is horrible getting the gaiter on. I ended up levering it with a blunt round ended kitchen knife. Good luck!
Fred, a silver 1998 1.9TD SX Xantia.
Gwin, a white 1994 1.1 AX.
xf1ref
- x 12
Thank you Jaf, I removed the nut but without moving steering from side to side and thought I have to remove the back screw from the ram, a torx t55. Tomorrow I will try again to get the ram of the stud.
VertVega
- x 13
xf1ref, check this thread for the steering rack gaiter (passenger's side LHD car) with some pics
---> Xantia - steering rack gaiter
xf1ref
- x 12
Thanks to all..I did it today and took 2 painful hours under the car with a lever and some gearbox oil to slide. Hope this stretchy gaiter to resist some years.
