evening all
new to the site
im replacing the injector pump shaft seal and thought someone must know were i can pick one up.
the pump number is nr 0460 484 055 ver425-2 xud201
also any body got a how to get a duff glow plug out that's been chewed up.
ive look through the stickys but couldn't find anything.
im in doncaster.
appreciate any help.
thanks phill
1994 citroen zx n/a bosch injector pump seal
fishermanphill2008
1994 citroen zx n/a diesel xud d9b
- x 94
Re: 1994 citroen zx n/a bosch injector pump seal
hi Phill
and welcome
one option
if you send me the last 8 digits of your chassis/VIN No. i will look on service citroen and get you price and part No.
option two would be contact the likes of
http://www.merlindiesel.com/" onclick="window.open(this.href);return false;
were are you located
and welcome
one option
Regards, malcolm.
fishermanphill2008
thanks for that citronut
problem is the zx had a lucas pump on which i changed for a bosch about 4 years ago.
the pump came off a citroen automatic so maybe it was a 2.1 engine.
this is a list of injector pumps and it doesn't seem to be on for some strange reason?.
http://www.dieselevante.it/fuelpumps/in ... OSCH&p2=VE" onclick="window.open(this.href);return false;
regards the glow plug could a nut be wielded to the glow plug to get it out.
phill
phill
fishermanphill2008
hi guys
pump problem fix by replcing it with a bosch pump off the same model.
thanks for all the help .
phill
phill
