Hi all,
Just wondering which alloys will fit my Berlingo van ( 2003 1.9D LX).
Don't want to go any bigger so a standard fit will do the trick.
I was thinking Saxo but I presume that you old hands will know the gen.
Cheers,
Outlaw.
the PSA wheels are 4x108 bolt pattern and vary from 10-30et offset, most of the wheels have the same central bore size too, without douible checking i would say pretty much any opf the psa 4 stud alloys would fit on fine,
also worth, many of the fords run the same bolt pattern but have different offset and central bore, - Due to offset will need spacer (spacers reduce the Offset number) which will sort the central bore problems,
Ford http://www.wheelfitment.net/ford" onclick="window.open(this.href);return false;
