Hi guys,
I have got a Citroen C5 X7 2010. Front airbags deployed and had to replace the whole dashboard and driver's airbags. With the airbag set I bought I was given a "new" clear airbag module. After fitting everything I tried to remove all errors what was successful however the airbag fault error keeps coming back straight after the ignition on.
I spoke to the guy who actually sold the airbags for me and he said that the problem is in the computer which doesn't see the previous airbag module just the new one and it needs to be reconfigured to the new module instead and everything will be working fine.
Does anyone know how do I do it ? Should Lexia be able to cope with that ?
Thank you very much for your help in advance.
Regards,
Thorvald
Airbag module configuration C5 X7 (2010)
- x 1988
Re: Airbag module configuration C5 X7 (2010)
Yep...Lexia is the real way.......where are you ?
thorvald
Thank you for your reply. I'm based in Birmingham. Can I ask a question on what option I should actually look for in Lexia to get that done ?
Thank you!
Regards,
Thorvald
Thank you!
Regards,
Thorvald
OnlineHell Razor5543
- x 3301
You could always start by looking for your nearest Lexia owner on this list, to see if they could help;
http://www.frenchcarforum.co.uk/forum/v ... 19&t=29178" onclick="window.open(this.href);return false;
thorvald
Thank you! I do have a Lexia on my own but I'm pretty new to it and I really look for doing it on my own even as an excersise
I have sent a PM to one of the Lexia owners who is quite active on the forum so maybe I will get a response. In meanwhile if there is anyone else who could advise me about the above that would be absolutely great!
Once again thank you very much for help!
Regards,
Thorvald
Regards,
Thorvald
thorvald
And just realised Stickyfinger is also a Lexia owner
- x 1988
However I am new to Lexia as well, I too would need to ask how
vborovic
- Locked user account
- x 40
Two heads are better than one, you'll think of something ...
