Has given me a headache since I bought the damn thing has had a habit of cutting out after the first mile or two of a journey whilst engine barely warm will restart after a while about 15 mins. RAC came out said its most likely the crank senor so had it changed day after same problem back to the garage they can,t find anything wrong with it engine won,t cut out. Has ran fine for a further two months and then oh bugger engine cuts out again after about a mile. I suspect head gasket as a creamy deposit on oil filler cap but garage says head gasket is fine. Engine does not overheat or tells you to stop no engine management light and no fault codes in the ECU. Feel like pushing the bloody thing of a cliff.
I wonder if anyone can shed some light on the subject.
