My crank pulley makes a noise and I can see red orange dust. The weather can effect the noise level sometimes to. So its time to change the crank pulley. But there 3 different types to choose from and which one the best?
Also what the difference between them all?
My crank pulley currently has the 3 groves on it.
306 hdi 1999
Crank pulley 3 different types
- x 94
Re: Crank pulley 3 different types
if you send me the last 8 digits of your chassis/VIN No. i will look on pug service box to get the OE price and part No. for you
Regards, malcolm.
Welshy_Pete
Hello sent in a pm thanks.citronut wrote:if you send me the last 8 digits of your chassis/VIN No. i will look on pug service box to get the OE price and part No. for you
- x 94
here is the part No.
0515 V6
DOUBLE DAMPING PULLEY
DIAM 162X30 EP 37 6V
and here is price and part No.
Reference Description Quantity Price - VAT Price + VAT Total + VAT Selection
00000515V6 DOUBLE PULLEY 129.81 GBP 155.77 GBP 155.77 GBP
just do a goooogly search with the part No.
pm. sent
0515 V6
pm. sent
Regards, malcolm.
Welshy_Pete
These have 3 years warranty and got the same part numbers there the solid type with out the rubbers.
link
http://www.ebay.co.uk/itm/CITROEN-PEUGE ... 3cd98f4dbe" onclick="window.open(this.href);return false;
link
http://www.ebay.co.uk/itm/PEUGEOT-307-2 ... 3a88725254" onclick="window.open(this.href);return false;
link
link
Oldpug
- x 93
These metal damper type pulleys do give a lot of trouble on HDi engines,and as you can see the Peugeot ones are very expensive.There are a lot of cheep ones about but they do not last long.The best make to go for is Lemforder,if you can find one? GSF car parts are showing O/E pulleys for £82.20,not sure what make they are though.
Welshy_Pete
So the Lemforder the solid type I take it?Oldpug wrote:These metal damper type pulleys do give a lot of trouble on HDi engines,and as you can see the Peugeot ones are very expensive.There are a lot of cheep ones about but they do not last long.The best make to go for is Lemforder,if you can find one? GSF car parts are showing O/E pulleys for £82.20,not sure what make they are though.
Everybody saying the solid type the best of the last 3 versions. The other 2 have rubber or spring and not as good.
- x 94
i belive thhe one that comes up for your car ( part No. above ) is a dual mass pulley
Regards, malcolm.
Welshy_Pete
So does that change the crank pulley I'm looking for with being dual mass pulley?citronut wrote:i belive the one that comes up for your car ( part No. above ) is a dual mass pulley
Oldpug
- x 93
All HDi crank pulleys are duel mass types,(or should be?)just make sure you get a O/E one and not a cheepo type.Even the gen` Peugeot ones give trouble.There is a huge spring inside,like grandfather clock spring.I`ve seen them come apart,the spring sort of unravels,on one occasion I`ve had the spring go through the timing cover and cut the cam belt !!!
After saying all this I have in the past fitted a normal XU diesel pulley(the one with the rubber middle)to a HDi.As long as the key way and the diameter for the 6K belt is the same,it will work. We could have the same discussion about the pros and cons of these duel mass pulleys as we have had with duel mass flywheels and solid flywheels??
