C5 2.0hdi Engine trouble Please Help!!
pdaly6
Unread post by pdaly6 »
Hi There,
Im new to this forum and french cars in general and would really like your help with this one!!
so to begin the saga I bought a c5 2.0hdi last year with the engine blown/cracked head and noisy bottom end. replaced the engine with a good s/h engine and got it going but and sounds lovely!! it revs to 3000rpm then stutters followed by grey smoke after this point. up till then it drives fine with no smoke once its kept below 3000rpm! any advice would be appreciated. Iv checked all the vacuum pipes and the egr valve. not so sure where to go from here. Also the Car will not start unless you actually put an earth wire fro the ECU casing to an earth point on the car!
thanks in advance.
Paddy
Xantidote
x 4
Re: C5 2.0hdi Engine trouble Please Help!!
Unread post by Xantidote »
Sorry I can't help you directly, not having a C5, but welcome to the Forum :)
Hopefully someone should be along shortly with a few ideas
Martin
1995 Xantia TDLX (deceased :( )
x 1240
Unread post by Peter.N. »
If this is an early C5 with the 8 valve engine they are normally bombproof, I have two of them with over 200,000 miles, it must have been very badly treated to fail. I would first try unplugging the MAF if it improves it needs replacing. The only other problem I have had is with the pump pressure regulator, these have a filter in them which can clog.
Richard Stevens
Unread post by Richard Stevens »
Welcome, Paddy!
When you earth the ECU casing for start, do you then remove it? And how did you find
that was what was needed?
You will likely get several ideas of causes for the 3k rpm limit, and one is that the fuel
filter may be crudded.
They do get filthy and can cause symptoms similar to yours. A friend with a Peugeot
with the 1.6HDI engine had just that problem and just that cure - a new filter.
Good luck.
1995 ZX Turbo diesel Volcane
1999 Xantia HDI
2005 C5 1.6 HDI
2006 C5 2.0 HDI Exclusive
Remember - many warnings are spurious or bad connections
pdaly6
Hi sorry only seen your reply now. The smoke and stuttering was down to a waste gate valve being stuck. The ecu casing was earthed because it wouldnt start at all and remembered working on a loading shovel where all the ecu s were earthed to the body so i took a chance on it and it worked.
Paddy.
zs&tas
x 16
Unread post by zs&tas »
just seen this and was thinking turbo related, since it kicks in at 3k ! glad i was right and your moving again !
