c5 2002 hand brake sticking on
colin machin
hi c5 2002 hdi hand brake sticking on on one side ive removed the hand brake cable and freed of the hand brake lever on the caliper using duck oil the lever was not returning freed it of its lasted two weeks and started sticking again is there any way to get in to the hand brake mechanism thanks
C5 2007 HDI
- x 2000
Re: c5 2002 hand brake sticking on
There are many many posts on the subject, I encourage you to search the forum for " C5 brake capliper"....enjoy the read.
As for your present situation, if it does not work loose by gripping the arm (mole grips) and pushing back and forth ( do this a LOT then some more then double again)....then its new caliper time.
As a temp measure...DO NOT use your handbrake unless you have to as you will destroy your disks if you don't notice. (I did!)
There are some good deals on the evilbay
A very common fault, however many cars have original calipers (both mine have) and high miles, so fair ware and tear
- x 2941
The levers get draggy or seized because the spring isn't man enough to pull them off, there are some suggestions for adding an extra spring in one of the threads stickyfinger mentions. A regular spray with something like 3 in 1 oil will help to keep the lever shafts lubed.
colin machin
THANKS FOR INFO IS IT POSABLE TO TAKE THE OPERATING LEVER OUT WITH OUT STRIPPING THE CALIPER TO AD LUBRICATION
C5 2007 HDI
- x 2000
Not in a way that is easy.
I tried to keep mine going and warped a disk = more $$
If it is a real sticky one then new calipers are the only way to go....http://www.ebay.co.uk/itm/Front-Right-B ... 1133235762" onclick="window.open(this.href);return false;
colin machin
- x 1240
Are you sure its not the cable that's sticking? If it is work some oil into it and saturate any cracks there are in the outer cover.
