Recently replaced, with a used one, the indicator stalk on the Saxo, mainly to get the horn working but it did also cure clicking from a relay connected with the indicators. If the stalk is moved slightly the relay stops rapidly clicking. Was in the car last night and the clicking is back with a vengence. Sounds like the relay is under the glovebox somewhere.
It was a bit of a fight to change the stalk so it's not something I'd like to repeat if I can avoid it. Would a dose of contact cleaner on the stalk likely help things, or is it worthwhile changing the relay?
Cheers
Paul
Saxo relay clicking
Saxo relay clicking
J reg 1.9d auto BX first Citroen
M reg 1.9d auto Xantia lx
N reg 1.9 td Xantia VSX Estate
T reg 2.0HDI Xantia Exclusive Estate Present car
M reg 106 diesel red
L reg 106 diesel white
02 Saxo 1.1i desire wife's present car(sadly now very ill cambelt gone- Doh)
Re: Saxo relay clicking
sorry but it is usually the stalk,
i think GSF sell new stalks ( no not the type that stand on one leg, or deliver babies )
you could try electrical contact/switch cleaner before you replace it again,
but dont use that orible W stuff
Regards, malcolm.
