ESP / ASR not functioning
ej2095
Unread post by ej2095 »
Morning all
I got this yesterday while driving about 25mph
Stopped car turned off and back on still came on.
So stopped car again at traffic lights pulled off lighty and it stayed off.
Jumped in car this morning started car and it came back on untill i drove about a mile or so stopped car turned off engine again restarted and it stayed off
Car did not go ito limp mode nor no anti pollution.
I did have the brake pads changed last week mind you.
Also seems to come on if road is wet and it was very very damp this morning...
C5 2.2 HDI Estate mk1 (With a anti theft fury dice device)
ej2095
Re: ESP / ASR not functioning
oh and i can deactivate with that esp button
lexi
x 134
Unread post by lexi »
You may have a speed sensor at wheel which has been disturbed.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
ej2095
Ahh how do i un disturb it..
Also what does it look like?
lexi
x 134
Check all wiring in and around abs sensors at wheels. ABS and ESP are usually related in circuit.
It could be connections elsewhere, all the way to and from your ecu that deals with these functions. Wiring may even be under a seat.
I am not familiar with C5.
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
x 2005
Unread post by Stickyfinger »
A faulty dash switch was the reason for my fault.....just after starting, and with the mode not showing as a fault, try the switch, mine thru a fault up when switched to off. I presume it was bridging but I hand one close by so I switched the module and all was OK.
More likely at the wheel end I would guess however.
ej2095
Will do
Get some electrical cleaner on the dash switch. as well
Poped on a couple of times over the weekend but was fine.
Just wait for the hail/snow/wind to bugger off first
ej2095
forgot to say i do have a sticky go faster button on the cruise stalk?
ej2095
oh and replaced the brake light switch... would this be worth taking out and lubing up with cleaner etc?
SaabC5
Unread post by SaabC5 »
Is your steering wheel centered after the new brakes were fitted, did they adjust track rod ends? I found i kept getting the same message after having the tracking done because the steering angle sensor noticed the steering wheel/front wheels weren't in unison. We then had to shorten one track rod end and lengthen the other to centre everything up and the message went away.
x 1488
You can't poke and hope - get it on a Lexia and find out what it is upset about!
ej2095
wish i had access to a lexia :(
x 3306
Next time I am up in Netherton (seeing family) I will bring mine with me. I cannot say when that will be though.
ej2095
ohhh coolios just round the corner ta..
speaking of tracking think mine is out pulls to the left
ej2095
Solved
The brake light switch i got off ebay was jammed so i had no brake lights.
I put the old one back on i had refurbed and all normal
