Hi All
I'm planning to replace the heater matrix in my "Sunday best" Xantia this weekend.
I've read the sage advice from a number of archive posts on the subject (thanks Jim !!) and ordered the O ring seals (part number 6564V1) from the local dealer.
He's just rung me back to say they are no longer available.
Presumably they are just O rings, so easy to find in the general parts market.............as long as the size is known.
In the good old days, Citroen parts manuals would helpfully provide the dimensions as part of the description, but alas no longer.
I don't suppose anyone out there is able to say what the required measurements are, please, so I can get some ahead of the weekend.
TIA
Andrew
Xantia heater matrix - O ring seals
CitroenCrazy
- x 65
citroenxm
- Fallen Hero
- x 70
Re: Xantia heater matrix - O ring seals
Ive NEVER needed to use replacement seals and ive done a good few matrixs.. so personally id not worry about changing them unless they have a knick in them or something..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
xf1ref
- x 12
Hi, when I changed heater matrix I recovered old O rings. I think you can use old O rings...at my xant even after 17 year O rings are good and I have no leak.
When you connect the elbow connector in the new heater matrix put some grease on O rings.
Good luck!
Good luck!
Xaccers
- x 188
Juliet blows the pipes off if I try and use o rings. Seals perfectly without then strangely enough.
DIY sphere tool
DIY sphere tool
- x 94
i just copied and pasted that part No. into service citroen and it came back as
6564 V1
NFP
RADIO RECEIVER
- "RD4" RDS COMPACT DISC AUDIO SYSTEM AND MONO RADIO TUNER UNTIL RPO 10801 EXCEPT JAPAN RADIO FREQUENCY
#missing#
"RD4" RDS COMPACT DISC AUDIO SYSTEM AND MONO RADIO TUNER SINCE RPO 10802
for a C5 and does in deed show as NFP = no f----ing parts
whilst the correct price and part No. is is showing as still available,
Part Number Description Quantity Price excl. VAT Price incl. VAT Total incl. VAT Selection
00006464V1 RING-SEAL 0.87 GBP 1.04 GBP 1.04 GBP
6564 V1
NFP
RADIO RECEIVER
#missing#
Regards, malcolm.
- x 94
ps.
and with an all families search they fit
11 document(s) found for BERLINGO
2 document(s) found for ZX
8 document(s) found for XSARA II
1 document(s) found for BERLINGO (M59)
13 document(s) found for XANTIA
8 document(s) found for XANTIA II
5 document(s) found for XSARA
Regards, malcolm.
CitroenCrazy
- x 65
Ahh, confusion and chaos reigns
First of all, I mis-keyed why typing the reference number into the original post. As Malcolm has pointed out, the O ring reference is 6464 V1
I did, however, give the Dealer parts man the right number, and he keyed it in wrong. He came up with something that cost 40p but isn't available.
So, the proper part, 6464 V1 is indeed still on sale chez Citroen, and for what it's worth, it has an external diameter (circumference) of 27mm and a thickness of 2.5mm.
Apologies all for the confusion.
evilally
- x 3
If you buy a Valeo matrix (which I recommend you do) it will come with the correct O rings. Does the Xantia have the same arrangement as the 406?
'97 406 1.9TD, 314k.
- x 94
here is the list from an all families search with the XANT matrix on pug service box
6 document(s) found for Partner (M59)
5 document(s) found for PARTNER
12 document(s) found for 306 (RESTYLING)
7 document(s) found for Partner (M59)
and from service citroen
4 document(s) found for BERLINGO
1 document(s) found for ZX
7 document(s) found for XSARA II
7 document(s) found for BERLINGO (M59)
1 document(s) found for XANTIA
4 document(s) found for XANTIA II
6 document(s) found for BERLINGO (M59)
2 document(s) found for XSARA
Regards, malcolm.
- x 94
ps.
here are the part No.'s for the 406 range
6448 77
NFP
CAR HEATER
TURBO DIESEL XUD9TE AND RIGHT HAND DRIVE UNTIL RPO 07980
6448 G9
RIGHT HAND DRIVE SINCE RPO 07981
and it shows the 406 matrix sliding in from the side of the heater box rather than the top, as XANT's do
6448 77
NFP
CAR HEATER
6448 G9
Regards, malcolm.
Xantidote
- x 5
I bought new matrix for my S1 a few years ago from local Citroen dealer, and the O rings were a separate item on the invoice, so I asume in my case that they weren't automatically supplied as part of the matrix (don't know if it was a Valeo)evilally wrote:If you buy a Valeo matrix (which I recommend you do) it will come with the correct O rings.
Martin
1995 Xantia TDLX (deceased
- x 94
the dealer does list the O rings as separate item's to the matrix,
but i think if you bought a Valeo matrix from the factors the seals are usually included
Regards, malcolm.
CitroenCrazy
- x 65
Alas no. Or at least not any more. The Valeo matrix I picked up from the local factors yesterday is an O ring free zone.
- x 94
have you checked in the dark corners of the box, just in case they are lurking in a small plastic bag
Regards, malcolm.
