C5 Front Suspension
SwissSPEC
C5 Front Suspension
Unread post by SwissSPEC »
Driving on Sheffields roads produces a clunking sound from the front of the car, as i don't have much experience of this type of car, is it likely to be:
Drop Link?
Tie Rod?
Ball Joint?
Suspension Arm?
Something else?
If i'm driving on smooth bits of road, no noise at all, there is a slight bit of vibration through the steering though, i assume linked to one of the above, or it may be worn tyres? I've not noticed any extra vibration through the steering when braking, the car also appears to pull slightly to the left.
Any ideas? Or could it be all 4 of the above :lol:
The car in question is a 2 litre HDI 110 Estate on a 52 plate with 115k on the clock, so not sure if there is a known weakness for certain parts if they are still orignal bits fitted 12 years ago?
Thanks for reading :)
CX GTI 2 Turbo (LHD) - Sorn
Bx Gti 16v
BX TZD Turbo - Sorn
C5 Mk1 LX 2.0HDi Estate
Mini Cooper D Clubman
x 2000
Re: C5 Front Suspension
Unread post by Stickyfinger »
A
hamster99
Unread post by hamster99 »
Yes, I'd suspect the drop links first as I had the same symptoms on my C5 but you should also check the other joints for movement and the strut tops where they are bolted to the inner wing turrets.
22 C4 1.6 eHDI Shine Plus
67 RR Autobiography 4.4 SDV8
15 C4 1.6 eHDI 115 Exclusive - fond memories
12 RR Westminster 4.4 TDV8 - Gentleman's Club on wheels
05 C5 2.0 HDI 138 Exclusive - gone but not forgotten
05 C5 2.0 HDI 138 VTR - crushed May 2015
SwissSPEC
Cheers, plenty of them on the bay of dread, are there any makes that i should avoid due to poor quality?
Bx Gti 16v
BX TZD Turbo - Sorn
x 3306
Don't know about ones to avoid, but Lemforder (I think I spelt it correctly) is a name that people like.
waynedance
x 8
Unread post by waynedance »
Moog seem to make decent suspension parts.
Sent from my GT-I9505 using Tapatalk
Volvo S80 D5.........
x 94
Unread post by citronut »
i personally steer well clear of that E bunch,
also if the car is pulling one way this is another issue and not the drop links
Regards, malcolm.
SwissSPEC
Malcolm, there may be more than one issue ;) Who knows, i'll need to get it looked at tbh, i haven't got a clue on these motors, i was allright on the BX, i guess my learning curve will be steep, & hopefully not in my pocket, haha...
Bx Gti 16v
BX TZD Turbo - Sorn
dnsey
x 19
Unread post by dnsey »
A lot of C5 stuff is very similar to BX, so you shouldn't find it difficult.
