Hi guys
this is my first time here so be gentle eh
ive just become the proud owner of a 1996 xantia 1.9 td sx
alas it has a few problems an i hav'nt got a workshop manual yet
so a couple of questions if its ok,,,,,,1st the speedo isnt working and i aint got a clue where it connects at either end,,,also dont know if its been disconnected for obvious reasons or what. also would like to know if its electric in anyway cos someone has made a bridge in the fusebox
cheers guys
jake
proud owner
Don't think so Jake - as this is also fairly easy to do on a mechanical cable speedo - and you'd be suspecious anyway.
The sensor is located where you'd expect to find the cable on the diff unit - right over the output housing for left drive axle.
My bet you have a perfectly common electrical cable/connector problem - either sheared cable or corrosion/dirt.
