My daughter in laws little 106 had a water hose break way from under inlet manifold. A little metal tube which is probably heat or cold sealed into bottom of manifold has rusted away.
Is this a regular occurrence and what steps can I take to fit a new one in- will have to be a home grown mod I expect ??
Are there inlet manifold gaskets available, or is it a silicon bead job ??
90 Kawa EN 500 A1- was running---now dead again
04 Kawa GPZ 500 E10 -alive and well.
54 Fiat Punto 1.2 Dynamic
Old Xantias- 16v 2litre 1997 VSX, 2 x 1993 TD Lx, S2 SX 1.9TD
Old Bx's--3 x 1.9 D, 1x 1.6 Auto, 1 x 1.9 GTi, 1 x 1.9 TZS
This might be a different size but I repaired something similar on a 205 by removing all the old pipe and driving in a piece of half inch copper pipe. Recently on a corolla I found a similar problem but when cleaning out the hole discovered it to be threaded. I cleaned the threads and found a hose nipple which threaded in.
The thread was actually cut by myself;-10 mm which was too loose, then 12 mm. The item I had to screw in turned out to have a ¼ BSP thread, so will have to make something up. This was an air hose connector which had a tapered thread.
A 12 mm bolt will be my first buy- drill it out and lop off the head. Probably cock the first one up, so better buy 2.
Greg
Yes a hose nipple or barb or attachment, depends who you are buying off. Probably taken off some air tool when I was fitting a PCL quick release fitting. You are probably using something similar. If you intend to drill through the bolt look for a 4.6 or similar low tensile as it will be much softer than 8.8. seal it with ptfe tape.
