When I had the C3 plugged into the lexia recently I noticed a couple of entries for cruise control/speed limiter. Does this mean I can fit it.
I know that on the C5 you can just connect the cruise control "stalk" below the lights and away you go. Is this the same for the C3 and if so can I connect the cruise control stalk from my C5.
Rob
C3 - Can I Fit Cruise Control?
hamster99
22 C4 1.6 eHDI Shine Plus
67 RR Autobiography 4.4 SDV8
15 C4 1.6 eHDI 115 Exclusive - fond memories
12 RR Westminster 4.4 TDV8 - Gentleman's Club on wheels
05 C5 2.0 HDI 138 Exclusive - gone but not forgotten
05 C5 2.0 HDI 138 VTR - crushed May 2015
Northern_Mike
Re: C3 - Can I Fit Cruise Control?
You can fit it providing you have brake and clutch switches present above the pedals. Have a look, plug the stalk in, make sure it's enabled in Lexia and try it. I know DickieG fitted it to his C3 last year sometime without much problem. The C5 stalk should be ok.
SaabC5
Can the C3 go fast enough to warrant cruise control?
09 C5 X7 2.0Hdi Exclusive in Perla Nera black (the best colour)
hamster99
- x 1488
It's the same part number in service.citroen, so it should work. You can look on Lexia to check that the clutch and brake switches are there, and working.
