Not sure if this is a good or bad sign or an impending fault. When I bought the xantia 110 Hdi back 6 months ago it did not sound like a diesel very quiet on idle and through the gears, yesterday I got the car back all that was attended to was alternator bearings replaced (making a whooshing noise on acceleration, noise present when I bought car) new drive belt, both front abs reluctor rings replaced, new pulley tensioner and both side airbag connections repaired/cleaned under both front seats.
The clock and date were incorrect which means the battery was disconnected and the ECU was unplugged as I remember it around the engine bay area.
When I started the car I noticed it sounded more like a diesel now on tick over and on acceleration, puzzled as to why the change of noise, ECU was unplugged for around 6 hours or so.
When I had it on lexia at savoy everything was ok regards engine side of things injectors and so on, so can't understand why the change of noise.
Thanks in advance.
Back from the garage
xantiagreen
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
96 Xantia 2lt 16v Sx Olive green
01 Xantia 110 Hdi
Storm Grey (SOLD 4/11/18)
Temporarily driving Polo 1.9sdi
All I want is a Bx Gti or 16v!
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
- x 1240
Re: Back from the garage
'Diesel' type noise is usually caused by injection timing being advanced but can't see why it should have changed. It can also be caused by the engine being cold, is it quieter when it gets warm?
OnlineHell Razor5543
- x 3306
Is it possible that when the battery was disconnected the ECUs have gone back into factory default? If so, won't they re-learn the optimal settings after a short while?
- x 1485
I've never noticed any difference in mine when the ECU has been disconnected. The HDi is 'quiet' by IDI standard, especially when warmed up. It's possible that if the alt was making a high pitched racket, it was masking any low pitched noise the engine was making. I would check that they have tightened up the intercooler hose properly, but otherwise I would ignore it!
xantiagreen
Had the car running for an hour yesterday and still can hear the engine on idle sat inside the car and more noticeable when outside. No loss of power and will have to monitor mpg, when outside of the car theres a slight metallic clangy noise that occurs every 5 or 10 seconds.Peter.N. wrote:'Diesel' type noise is usually caused by injection timing being advanced but can't see why it should have changed. It can also be caused by the engine being cold, is it quieter when it gets warm?
Going to get the service book stamped will ask mechanic to run diagnostics and check hoses and other areas members have mentioned.
Cheers all.
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
electronmirror
- x 31
That " slight metallic clangy noise that occurs every 5 or 10 seconds" might be a sign of a knackered accumulator sphere.
To check, you should be able to feel it by putting a hand or use a long screwdriver/stethoscope on the sphere/regulator, it's visible just behind the radiator on the right hand side.
If the accumulator is not replaced there is a risk of high pressure hydraulic pipe fracture, an undesirable scenario
A healthy accumulator should produce that sound at not less 30 second intervals.
Ted
2010 C5 2.0 diesel(163) Exclusive Tourer (135,247miles)
1999 Xantia Exclusive Estate 110 Hdi Mauritius Blue with self peeling lacquer finish (276,174miles)
1991 XM Prestige 2.0 Auto(157,000 miles) gone but not forgotten
xantiagreen
Had all spheres changed 6 months ago by Dugg at westroen, acc sphere certainly working fine clicking at right intervals. Could it be with the new belt, tensioner pulley being fitted that it's brought all movement a bit tighter causing the diesel type noise.electronmirror wrote:That " slight metallic clangy noise that occurs every 5 or 10 seconds" might be a sign of a knackered accumulator sphere.
If the accumulator is not replaced there is a risk of high pressure hydraulic pipe fracture, an undesirable scenario![]()
Cheers Ted
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
