Mechanic's labour charge
xantiagreen
What would be the minimum/maximum labour charge for the work below:
Remove alternator and refit (bearings replaced from Auto electricians)
Fit new alternator belt
Fit new pulley tensioner
Fit new ABS reluctor rings front offside and nearside
Diagnostics for side airbags, unclip clean and lube up connections under passenger and drivers seat.
Alternator bearings replaced for £30
Alternator belt £11.98 (Gates)
Pulley Tensioner £37.50 (Dayco)
Reluctor rings x 2 £29.98 (Ukpartsdirect) - 10 year guarantee, pro coat corrosion protection
Thanks in advance.
Thanks in advance.
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
96 Xantia 2lt 16v Sx Olive green
01 Xantia 110 Hdi
Storm Grey (SOLD 4/11/18)
Temporarily driving Polo 1.9sdi
All I want is a Bx Gti or 16v!
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
Northern_Mike
Re: Mechanic's labour charge
About 3 hours, depending on where you are, that's going to be anything from £100 to £195 from my experience, plus the VAT.xantiagreen wrote:What would be the minimum/maximum labour charge for the work below:
Thanks in advance.
Where in Lancs? I'll be up there in a couple of weeks once I'm fit. I can read your airbag diags from your car..
addo
- Sara Watson's Stalker
- x 95
Yes, three hours should cover it, to the state of delivering a tidy car free of fingerprints and having had a basic look-over everything else. If a car came in with corroded ABS rings you would be remiss not to look at the rest of the brakes.
If you rushed, less, but you'd then be catching your breath/tidying up before the next job so it's a false saving.
xantiagreen
[About 3 hours, depending on where you are, that's going to be anything from £100 to £195 from my experience, plus the VAT.
Where in Lancs? I'll be up there in a couple of weeks once I'm fit. I can read your airbag diags from your car..[/quote]
Was charged £120 inc VAT (Sorry drivers side reluctor snapped causing braking fault and passengers side was good but had it replaced with the pro coat ones)
Would you say £70 inc VAT to take alternator out and refit is reasonable (that was where most of the cost was billed)
I'm up in Preston.
Cheers Mike
I'm up in Preston.
Cheers Mike
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
xantiagreen
Re:
Sorry the drivers side ring snapped and passenger side was in good condition, but replaced both with pro coat versions.addo wrote:If a car came in with corroded ABS rings you would be remiss not to look at the rest of the brakes.
Cheers mate.
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
- x 1486
So about 1 hour to do both the ABS rings, which is about right - wheels off, crack hub nut, split bottom ball joint, pull shaft out of hub, remove remains of old ring, clean the shaft up, heat ring and slip it on, reassemble.
And about 1.5 hours to do the alt (and tensioner I think?). It's not that easy on a 110HDI: ECU and box out, intercooler outlet pipe off, oil filter off, relieve aux belt tension, move some of the cable ducting a bit to get access to the bolts, undo 4 retaining bolts (one through wheel arch, so liner needs to be pulled back), undo the wires, wiggle the alternator out past the PAS pipe (not easy!). Changing the tensioner then requires some engine up/down activity AFAIK, so engine mount needs to be undone.
Rhothgar
- (Donor 2026)
- x 221
That's cheap.
You been charged £120 for all that work and you're now isolating the alternator removal and refit to see if that aline is too expensive.
If you can't do the work yourself then it's a bargain. Christ alive! You've paid £40/hour if 3 hours is the scheduled repair time.
Next time take it to Citroen. You'll feel much better off when you receive their bill.
Northern_Mike
That's a bargain. 3 hours work for £120 inc vat? Even our cheapest local Independent charges £65 per hour *plus* vat.xantiagreen wrote:
Would you say £70 inc VAT to take alternator out and refit ...
Rhothgar
- (Donor 2026)
- x 221
Exactly. My best mate charges £45+VAT an hour. I don't know how he does it so cheap.
He's often buying a £20k piece of equipment here and £10k diag kit there!
xantiagreen
The chap that carried out the work is a citroen specialist, trust his work and never argue over pricing. No harm in getting views on the matter, back in '91' or '92' I was charged £20 for less than 5 mins work, the damn recovery truck was parked opposite. I had reversed the bx into a high kerb at a service station off the M1 and bent the tailpipe (inexperienced young driver) recovery chap noticed us staring at the rear and shaking our heads and must have thought kerchingg. Any way he stuck a crowbar in and opened it up and robbed us. when we got back home to lancashire i got the rear box changed at kwik __t £35 or so as i knew if my dad saw the modified tailpipe i'd be dodging a barrage of slippers like Mr Bush (my dads laser sighted strikes never missed a target)Rhothgar wrote:That's cheap.
Lesson learned, never take out your wallet/purse unless you've agreed a final price, or in this situation get in the car and do a runner.
Cheers.
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
flying clutchman
- x 3
You didn't pay £20 for five minutes work. You paid for his Knowledge and ability and use of his equipment. I'm glad you don't live in essex!
xantiagreen
knowledge and ability my a**e, more of I can milk £20 from them. It's not as if we called him over he came over and offered to help and then charges as if he'd struggled at it.flying clutchman wrote:You paid for his Knowledge and ability and use of his equipment. I'm glad you don't live in essex!
Aye Aye Clutchman
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
qprdude
- x 14
You were perfectly at liberty to refuse his help then. He had a crow bar, you didn't.
Rick.
2013 Citroen DS 5 D/Sport
xantiagreen
Point is if someone offers to help without you asking them then their should be no financial gain, unless you have asked for their help. The recovery chap knew he was going to charge and didn't say so before he started the 5 minute work out. If I've offered my help to someone without them asking me it would be stupid of me to then say that'll be £50.qprdude wrote:You were perfectly at liberty to refuse his help then. He had a crow bar, you didn't.
It negates him "helping" us because he charged us (underhanded manner) car was ticking over without any problems even with the tailpipe bent.
Cheers.
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
Northern_Mike
I'm with Xantiagreen on this. If the chap had said "I'll fix it, it'll be £20", then fair enough, it's £20. If he just offered to help, then said "thanks, that'll be £20", it's out of order.
