air filter box on c3 2010 Citroen C3 Picasso Airdream+ Hdi
celticguy
any body no how to get the air filter out of the air box on a Citroen C3 Picasso Airdream+ Hdi 16 90 2010 do i have to take the box out of the engine compartment or what i can see is take the top off of the air box thanks to any one that can help me out
- x 1487
Re: air filter box on c3 2010 Citroen C3 Picasso Airdream+ H
You take the top off - there are 3 (long) screws along the front edge (4mm allen IIRC). Depending on access to the top of the engine, you might need to remove some of the trim / deadening above it. There are some clips along the back of the lid that need the lid to be wiggled to finally free it. If the fuel filter has not been changed in the last 20-30k, then you might as well do that while you are there - they get blocked and cause running problems, and to change it means removing the air filter lid....
