Rang up GT to ask for a poly v belt and was asked whether I had a Sanden or Delphi compressor, how do I find out which one is fitted and where is it located.
2001 Hatch Xantia 110 Hdi.
Thanks.
Aircon unit
xantiagreen
Aircon unit
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
96 Xantia 2lt 16v Sx Olive green
01 Xantia 110 Hdi
Storm Grey (SOLD 4/11/18)
Temporarily driving Polo 1.9sdi
All I want is a Bx Gti or 16v!
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
- x 1240
Re: Aircon unit
Follow the belt, it will be the thing that doesn't look like an alternator or hydraulic pump. Should have a label on it - if you can see it.
xantiagreen
Re: Aircon unit
Cheers Peter, will I be able to locate and read if I look from top down or will I need to take under tray off and rummage from underneath.Peter.N. wrote:Follow the belt, it will be the thing that doesn't look like an alternator or hydraulic pump. Should have a label on it - if you can see it.
Been told it's either 1735mm or 1750mm from GT, Euro have said only stock one Conti brand £12.50 1740mm.
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
- x 1486
Re: Aircon unit
You need to look from underneath - the compressor is on the bottom. However, if you post up the last 8 digits of the VIN, we might be able to confirm via service.citroen.
xantiagreen
Re: Aircon unit
Forgot to ask the mechanic what compressor was fitted, belt used was 1750mm think it might be a Delphi.
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
John Plum
- x 5
Aircon unit
I've got a 1735mm belt fitted at takeover, which spells a Sanden, but I don't trust what's given. I can't recognise the compressor from the label - it's a thin band and quite worn. I can tell from the label, capacity is 9 fl oz. it has in bold 5290 on the label
Checking servicecitroen I only found options, not definition, but perhaps I don't know so well, how to use their system.
From looking at images in the net, the body looks more like a Delphi.
Any clues anyone?
Sent from a mobile transmitter.
Any clues anyone?
John Plum
Xantia II Estate,1999, 2.0 HDI LX, 17000 miles, manual
