Hi
I felt some bangs from the AL4 gearbox and hooked the Lexaia. I got the "Regulating fault". Has anyone experienced this fault ? I tried to track it down and got to the conclusion that it may be the pressure regulation electro valve or the pressure sensor. Is there a way to point which one of the two is failed ? Can there be other cause to the fault ?
Xantia - AL4 Regulating pressure fault
lancia58
- x 8
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
addo
- Sara Watson's Stalker
- x 95
lancia58
- x 8
Re: Xantia - AL4 Regulating pressure fault
It turns out that 1 liter of ATF missing. Adding it sorted the fault
Zohar
Zohar
Mandrake
- x 695
But where did it go, and how long has it been missing ?
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
Clogzz
- x 40
It has evaporated; like mine that’s gone low without any leaks.
lancia58
- x 8
Hi
For time to time when I lifted the car I could see that the gear box is wet, I guess it was ATF ( the liquid was transparent ) , the mechanics told me that I can ignore that leak. As a lesson each six month I'll add ATF. Anyway I am going to detach the gear and sort the leak
Zohar
Zohar
