Memory Saver when welding
Taffyrhys
Unread post by Taffyrhys »
I don't know my radio code and was wondering if i could use the memory saver that plugs into the cigarette lighter , so when i disconnect the battery when welding, i don't lose the code to the radio?????????????
Any ideas???? :-D
Cheers Ade
gadgetgricey
Re: Memory Saver when welding
Unread post by gadgetgricey »
What type of Radio, as aware you can get the code quite easily from some Citroen Radio's via the S/N on the side...
Cheers
Dave
C8 - Petrol Auto (Love the electronic doors)
Xantia Hdi Exclusive Estate (gone but not forgotten)
dnsey
x 19
Unread post by dnsey »
To avoid potential damage from stray current when welding, you need to short the battery leads together, so you won't be able to use a backup 'memory saver' battery.
qprdude
x 14
Unread post by qprdude »
Depends what your car is. Some don't have codes, they are paired to the car.
Rick.
2013 Citroen DS 5 D/Sport
