Finally got around to servicing the old girl and am now going to give a remap a try.
I want to get some live data before and after. The before will be to get base results for comparison and also to check everything is running as it should. The after will be to see what parameters have changed and the effects.
The data I thought about capturing is listed below in no particular order.
Coolant temp.
fuel pressure
turbo pressure
speed
rpms
mpg
throttle position
Any other things you think I should monitor?
I will video the data over both runs and will drive the same route to get the best comparison.
2.0HDi remap. Before and after Lexia live data.
jotto
Xsara Picasso 2.0 HDi ( 53 plate )
antonioneves
Re: 2.0HDi remap. Before and after Lexia live data.
injector duty cycle and common rail pressure and most importante oil temp althou to check oil temp you need some time driving in the motorway or giving it a good trash.
amanico
Hi Jotto, did you ever record the before and after readings for your engine? more importantly, if you did, do you still have that before/after data?
Thanks.
Thanks.
