advise for rear view mirror
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Hi all..
advise. Best stuff to stick a rear view mirror back on the windscreen permanently. . On a xantia hdi lx .. no auto wipers.
cheers
A very sad...
1994 XM 2.1 d auto
x 3306
Re: advise for rear view mirror
Paul, you might want to ask isisalar. I think he used to work in windscreens.
x 5673
Ford have a very sticky pad to fix rearview mirrors to the screen, better than any other you can buy.
Deanxm
x 87
Unread post by Deanxm »
Drop into your local windscreen fitting place, they will put them on for you for about £5, i think they charged me £3 at autoglass a couple of months back when i took the Merc in, not worth piddling about yourself for that money.
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
citroenxm
Fallen Hero
x 70
Ahh excellent Dean, I shall sugest it, deafenatly NOT worth the messing for that!
A very sad...
1994 XM 2.1 d auto
isisalar
x 3
Unread post by isisalar »
For a DIY job the best I have found is the Loctite one with a fine mesh pad, which activates the adhesive, this one :- http://www.amazon.co.uk/Interior-Rear-V ... B004ROTY6G" onclick="window.open(this.href);return false; I have known sticky pads to work, but they usually fall off. In either case the surfaces must be ultra clean, I always rub down the metal fixing bracket to bare metal with fine sandpaper (can't get cleaner than that), and clean the screen with meths.
Stuff sets in about 20 secs IIRC.
DO NOT USE SUPERGLUE !!!!!
Cheers
Paul
J reg 1.9d auto BX first Citroen
M reg 1.9d auto Xantia lx
N reg 1.9 td Xantia VSX Estate
T reg 2.0HDI Xantia Exclusive Estate Present car
M reg 106 diesel red
L reg 106 diesel white
02 Saxo 1.1i desire wife's present car(sadly now very ill cambelt gone- Doh)
