Fuel filter
qwerty
Fuel filter
Unread post by qwerty »
Hi
Is there any problems changing fuel filter on hdi diesel engines
spanner 1
Unread post by spanner 1 »
THERE IS NO PROBLEMS CHANGING FILTERS ORIGINALLY PSA TOLD YOU TO REPLACE COMPLETE HOUSING AND FILTER AS NOT TO BREAK SEAL SO WOULD NOT GET CONTAMINATED BUT BOTH CITROEN AND PEUGEOT SELL THE ELEMENTS SEPERATE THERE ARE 2 TYPES ON THE DW 10 DEPENDING ON YEAR ONE TWISTS ABOUT 45DEGREES THE OTHER UNSCREWS JUST BE VERY CLEAN WHEN CHANGING NO NEED TO PUMP UP WITH BELLOWS WHEN DONE AS SCAVENGER WILL FILL FOR YOU.
