Interior drivers side door handle
kettlesimon
Unread post by kettlesimon »
Bit of a problem today was getting out of the car and trying to open the door with the silver handle and it snapped off in my hand. So at the moment i have to put the window down to get out, by using the outside handle. Looked on EBAY and there are replacement items at @ £25 new, or less from breakers yards. Anyone else had this problem and what are the obvious problems with fitting a replacement one. Is this something that i can do, or is it a garage job. All feedback gratefully received.
Forgot to say its a 2004 C5 2.0HDi
2004 C5 Estate 2.0 HDi
x 5671
Re: Interior drivers side door handle
It is fairly common and there are a couple of members who have experienced it. Not me though, although it did happen to my estate after I had passed it on :twisted:
I'm sure someone with concrete advice will be along soon.
waynedance
x 8
Unread post by waynedance »
I guess this is a mk1, if so I believe its a door card off job and you may want to get some of these clips and you will break some.
Door card comes off quite easy, if you need help I can give instructions.
http://www.ebay.co.uk/itm/10X-CITROEN-I ... 1c38153b9e" onclick="window.open(this.href);return false;
Volvo S80 D5.........
wellad
Unread post by wellad »
It's a handy job to remove the door card, maybe an hour in total for the job if you take your time. I'm sure the experts could do it in 10 minutes, it's very straight forward. The handle is held on with one bolt, and the bar going to the lock. A rear handle will fit the front, by shaving a small bit off the clips at the rear, and the rears are usually a few £ cheaper on ebay. Structurally they're the same front and rear, and the bolt makes the clips unnecessary. As above, stock up on the clips beforehand, they're pretty much single use.
2003 Citroen C5 2.0 HDI 110
