I have a Xantia S2 V6
Northern_Mike
And it mostly works.
No 100 pages threads here, nothing to see, move along please.
Northern_Mike
Re: I have a Xantia S2 V6
If it's the engine or box, I shall simply laugh and send it on it's way. If it's anything else, I'll fix it if I can be bothered. I've better things to do!
Northern_Mike
It's probably the best way isn't it?superloopy wrote:Not going to hit the heady heights of Simon's post then, maybe a couple of pages, keep it short and sweet
- x 3283
Have fun with it. Other than the airbag issue, what (if anything) is wrong with it?
BY the way, if needed I have a Lexia available.
Northern_Mike
I suspect the ride height is a bit high and the horn doesn't work, which will be the same cause as the airbag.Hell Razor5543 wrote:Have fun with it. Other than the airbag issue, what (if anything) is wrong with it?
Oh, and it decided to demand the radio code from me after I started it earlier, which I found, but put in wrong, so it's locked me out for a while,. Other than that, it's spot on.
I still have a Lexia, I just need to install a virtual machine
KP
- x 27
Time for a mod to move the thread I think
bxzx16v
- x 34
Good luck with the V6 Mike, they can be temperamental old things but are worth it
Mark
Mark
Chris570
- x 36
My apologies Mike, I didn't know about the horn, otherwise i would have told you!Northern_Mike wrote:I suspect the ride height is a bit high and the horn doesn't work, which will be the same cause as the airbag.Hell Razor5543 wrote:Have fun with it. Other than the airbag issue, what (if anything) is wrong with it?
The radio code, did it prompt for it outside Liam's house? Reason I ask is the car hasn't done a long run for a while so it could just be a low battery, but i'm sure you'd already have worked that one out.
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'CitroJim wrote: I'm a pink fairy
Northern_Mike
I know that Chris! I wasn't expecting it to work anyway. I never use it. It was Sam who discovered that it didn't when he asked me what the picture on the wheel was then wanted to hear it.Chris570 wrote:My apologies Mike, I didn't know about the horn, otherwise i would have told you!Northern_Mike wrote:I suspect the ride height is a bit high and the horn doesn't work, which will be the same cause as the airbag.Hell Razor5543 wrote:Have fun with it. Other than the airbag issue, what (if anything) is wrong with it?
The radio asked for the code outside my house, which was odd. Of course I put it in wrong and blocked it. Drove to work and back waiting for it to reset so I could try again. . It didn't let me.
Then I read the manual and found you simply hold one of the buttons down for a few secs and it unblocks it. No waiting required.
Great car. Sam has declared it "awesome" and "a bit fast".
Trainman
- (Donor 2018)
- x 43
You're not wrong there Mark, they sure are.......bxzx16v wrote:Good luck with the V6 Mike, they can be temperamental old things but are worth it.
Mark
Steve
http://c6owners.org/index.php
Mandrake
- x 694
Congrats on the purchase, especially after saying recently you would never buy another Citroen again let alone another Xantia. Never say never eh ?
Let's hope you have better luck than me...
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
Northern_Mike
To be honest, it was the power and leather I'd been missing. If I could have bought something so well equipped for what I paid that wasn't a Citroen, I would have done.
Northern_Mike
I did, and I almost meant it! I've had so many of them and I'm fed up of weird random problems with them, electrical mainly.superloopy wrote:Did you say that, really?Mandrake wrote: .... especially after saying recently you would never buy another Citroen again let alone another Xantia. Never say never eh ?![]()
Northern_Mike
I'd be willing to bet money that I've owned more Citroens over more years than most people on this forum, as well as having a former life as a dealer trained mechanic. If that doesn't make me a genuine enthusiast, I don't know what does. I've just got better things to do with my spare time these days, like play with the kids or do non-car related stuff, or travel. People tend to forget we only have one shot at life and I'm damned if I'm spending it stressing about weird random problems.superloopy wrote:Welcome back then ... even though i doubt you'll be around for long. 'Weird random problems' have an attractiveness to genuine citroen enthusiasts
