Coolant warning
ej2095
Coolant warning
Unread post by ej2095 »
Odd this
I parked ca last night on kerb and half on road so car was at an angle.
Had a damp night with frost this morning jumped in car this morning it said check coolant...
So i put car on flat service checked it was fine?
Jumped back i car and no more warnings...
drove to work with heaters keeping me toasty and all was fine...
Wondering if the sensor was being a bit wierd...
C5 2.2 HDI Estate mk1 (With a anti theft fury dice device)
x 3306
Re: Coolant warning
It depends on where the sensor is mounted, and the angle of the car. If there is a sensor in the expansion chamber, and the angle allowed it to be above the coolant level, then it would 'believe' the coolant level was too low. I have had something similar when Gracie was parked at a sufficient angle for her to 'believe' there was a problem with the oil level, and to flash the 'dipstick' light for 15 seconds. When she was parked on the level, there was no problems.
ej2095
Re: Coolant warning
yup sensor is on top in my c5 black thingy on the expansion bottle
x 3306
Re: Coolant warning
Then the sensor got dry overnight, couldn't tell why, and let you know it thought there was a problem. Once the car was on the level, the sensor got wet, and it then could see there was enough coolant to stop the car overheating. It is better to have a false alarm (in my opinion) than no alarm when a problem might exist.
ej2095
Re: Coolant warning
I agree i kept an eye on the temp guage all the way into work only a short 4 mile trip (IT Person so need go to lug gear around)
Seemed fine.
This time last year me vectra died a death due to blown head gasget.
